How do you apply plastidip? I have heard that it needs little prep. Where can you buy it?api330 said:markeg said:api330 said:I might have a go at painting them, To remove them I belive you just pull them up and out at the same time, Is this correct ?, Does any one no if you can spilt the chrome part from the black part once removed ?, Thanks Tim.
Yes, the OEM ones can be split. I used Pastidip on mine, has lasted for over 6 months, no chips, tears or wear, and an easy top over/removal if required.
Thanks for the info, Do they just pull up and out to remove them. Thanks
