Bizarre Hive Issue, HELP!
sars
Awesome
 East Yorkshire
Earlier today I noticed that the hot water was on, about fours hour before it should have been, looked at the thermostat and noticed the time and day was wrong. I assume it’s not connected to the hub, so go through the rigmarole of reconnecting everything, replacing batteries etcetera, still nothing, check that I can connect to the system from outside using 4G, yep can see and set the temperature etcetera but the time and date is still wrong :|
I can’t see a way to manually change date and time as it’s automatically done from Hive HQ, I’m thinking that the issue is with them not me, so anyone else with this issue?
I've contacted hive using Twitter before, an help has normally been quick and sorted issue, hope you get it resolved
