And had the N52 which is probably a different weight, hence the different shock.Gregory_tolson said:The si didnt start till like 2006
Haha, BMW definitely was quirky with their PN's. Though it always amazes me how similar this car is to the e46Dr. Zed said:Gregory_tolson said:yeah, real oem must be searching your VIN # wrong. Search solely based on what your car is versus the VIN.
I did this after you mentioned the 3 litre thing.
Parts are now showing the same as you and enuff zed. Not that it matters ultimately as it's still the same B4 suspension I need but was just confusing me so much why it was different!
I agree. Exactly what I was saying earlier about the rears. If the car is a keeper and you're not on a really tight budget then do the front springs while its all apart.Rockhopper said:While you have the front struts apart you'd be daft not to swap the springs. Rear ones are easy to do with hardly any tools but the fronts are scary! No doubt someone will be along to say the opposite though![]()
enuff_zed said:I agree. Exactly what I was saying earlier about the rears. If the car is a keeper and you're not on a really tight budget then do the front springs while its all apart.Rockhopper said:While you have the front struts apart you'd be daft not to swap the springs. Rear ones are easy to do with hardly any tools but the fronts are scary! No doubt someone will be along to say the opposite though![]()
Don't find the fronts scary tbh, but then I've had plenty of practice now.
enuff_zed said:I'll be honest, I think 30-40k on any standard set of shocks is reasonable considering the life they lead.Rockhopper said:I've put B4's on my car - no idea on longevity yet but BWM OEM are Sachs and on my 100,000 mile old car the rear ones had been replaced at least once before so lets say 50k miles and they are shot (and not just a little bit shot - zero damping at either end). I personally don't think that's very good!
Oh whatever.......... :roll:SonnyA85 said:enuff_zed said:I'll be honest, I think 30-40k on any standard set of shocks is reasonable considering the life they lead.Rockhopper said:I've put B4's on my car - no idea on longevity yet but BWM OEM are Sachs and on my 100,000 mile old car the rear ones had been replaced at least once before so lets say 50k miles and they are shot (and not just a little bit shot - zero damping at either end). I personally don't think that's very good!
It's well known the oem/sachs only last around 30K. Bilstein's will last 60K+ easy.
Have a search on the forums to confirm the above but Bilstein's are built to a much higher standard. In fact to confirm what others have said on the forum my mechanic just called as he's coming to do the EGR on Friday and he said himself Bilsteins are a quality shock as I'm just about to plac emy order and sent him a screenshot to double check everything before I do. 37% off today on autodoc and I have a visa card which gives me 5% cashback on the total amount too.
kis said:Late to this epic wanted thread but I find myself in a similar situation. I’ve got shocks (sach) and will be reusing the old rubber dust shield. I’m pairing it with my m sport springs… question is what bump stops or dust shield kit do I need to buy? Or will any be compatible?
OK, please ignore certain inputs. :roll:kis said:What about 900 132? AUTODOC
