Two years with mine, travelled Newport, Wales over to Bristol on the train then bus ride to vendors house a few days after going by road to check it out. On that occassion he was OK with me plugging the laptop in and scanning the car, nothing showed up as faulty, did spot cam cover gasket leak and after a short test drive agreed on a price less £200 than the asking price to cover the repairs it needed. Had previously looked at another one in Taunton and that was a dog so couldn't walk away from this one. In the two years I have had it put a different sent of wheels and tyres on it, replaced starter motor and sorted cam cover and oil filter gaskets. Oil level sensor replaced but it already needs another one, will do that next oil change. Invested in a run flat for a spare and moved the hood motor to the boot, that was in fact the first thing I did to future proof it as the car lives outside. Also fitted a pair of led DRL's to the lower grill, helps to make the car stand out to other road users as the car is Silver and can blend in to the road surface. Latest replacement is an Alternator that packed up a few weeks ago, fitted a used replacement and will be having the failed one reconditioned locally and will fit that when done.
Now got 94k on the clock and runs fine, enjoy trips out as often as I can.
