Mos6689 said:
Yea had a new one 3 times already
totting up when I was younger!
I’m not just spending money for motorway miles & straight line speed. I want to be able to push the car when the feeling takes & have confidence in it. Loads of great B roads down here in Surrey. Stock suspension does not give me any confidence at all. Maybe just the nature of the car but surely it can be improved on without sacrificing comfort & increasing NVH.
Maybe KW’s & a bush refresh will be enough. Car has only done 22k though so don’t know how much play the bushes are going to have. Visually there’s no cracks or splits on ones I can see without putting it on a ramp. Then again rubber does deteriorate & the car is 15 years old.
I replaced my rtabs at similar mileage, they were like new still.
Personally I wouldn't bother with a bush refresh unless you know or have a good idea they are worn which I can't imagine at that mileage unless it's done a load of track work.
You need to realise just how bad the oem suspension is, genuinely it's blumin awful, it's not you, it's the suspension hence the lack of confidence.
KWs will fix the ride, the feel, the compliance and give you loads more confidence in the car. Personally I'd do the rtabs at the same time as it makes a genuine difference to rear end feel and it's a cheap mod. What you don't want to do is do the KWs, pay for a geo, then wish you had done the rtabs and have to it all again.
Arbs, for road use, you won't need them it, it just adds more to the mix. Again it's very personal preference. You can add them later though with minimal interference to a fast road geo.
It's tough though, everyone always has an opinion I guess that's why you ask
If your close ill take you for a spin in mine
