mr wilks said:4zwmb said:Check this link guys, its by varta, tells you exactly what kind of battery is needed for all types of cars. After searching mine, it seems that Mr Wilks did choose his battery type correctly!On the other hand it also gives a second recommended battery which is 80AH and 800CCA. So I dont really think one has to replace the battery with a new one of the exact same specifications.
https://www.varta-automotive.com/en-gb/battery-finder?type=pc&year=2011&make=16&model=8033&engine=31018&etn=580+901+080%7C570+901+076%7C&rec_etn=570+901+076%7C&ss_etn=580+901+080%7C570+901+076%7C&literal_search=%7B%22type%22%3A%22Passenger+Car%22%2C%22year%22%3A%222011%22%2C%22make%22%3A%22BMW%22%2C%22model%22%3A%22Z4+Roadster+%28E89%29%22%2C%22engine%22%3A%22sDrive+30+i+%28190+kW+%2F+258+PS%29%22%7D
I was lead to believe that getting the exact same numbers was important & over capacity could be as bad as under capacity :?
No, I dont agree fully...I am a physics teacher, I would rather believe that under capacity would be wrong but not over capacity. CCA is the ability of the battery to start the motor at zero degrees Fahrenheit whilst trying to keep a voltage of at least 7 volts. Hence over capacity is not wrong at all when it comes to CCA. Now back to AH. 80AH means the battery can take a little bit longer strain than a 70AH. See, an 80AH battery can give you 0.8AMPS for 100 hours or 8AMPS for 10 hours or say, 80amps for 1 hour technically. In reality we only get just a mere close to this because of a lot of factors like temperature, efficiency of a battery etc....So in my opinion, the only think that can happen with an 80AH instead of the 70AH, is that the alternator just wont charge the battery to say 80% as it used to do to the 70AH battery before since it wont recognize that the new one has 10AH more. So for example it will charge it to just 70% instead. Somebody prove me wrong here, I will appreciate it!!!
