mr wilks said:Connect another battery or charger to the points under bonnet![]()
pHilli0 said:mr wilks said:Connect another battery or charger to the points under bonnet![]()
Ah will this give it enough to pop the boot using the button?
Thanks ill google the points under the bonnet before I screw it up
aarsavage said:The boot lock should work, I've used mine with a dead battery.
aarsavage said:The boot lock should work, I've used mine with a disconnected battery.
Havard said:
pHilli0 said:Havard said:
This was massively helpful thank you for taking the trouble
