Thanks Silverstar
I was not going to change the rears as I understood it was not worth it unless changing the amp (beyond my skills). However (and I know sound is subjective) did you do this and see an improvement with the original amp? I agree it would make sense to get the component set as the crossover cables are smaller than the box I was looking at.
I was going to see how the door speakers made a difference and then maybe upgrade the foot speakers to the same ones mentioned in the start of this thread.
Silverstar said:Yoghurt said:Finally got round to adding the Crunch door speakers using the advice here which was great.
To save me taking the door card off again I added some additional wire from the door speaker and left it behind the tweeter housing which is currently empty.
Thinking of getting these matching Crunch tweeters.
Need to find a place for the Crossover box, assuming I need it?
https://www.ebay.co.uk/itm/265690069408?epid=1337164040&hash=item3ddc5cb9a0:g:x0EAAOSwPpRifiMH&amdata=enc%3AAQAIAAABACewWvPTPNt%2FtWswJ%2BILimIpNDQ2D5FWZNnvEPzGtARthNWBxPey%2BZqBFhpnH2Eo9sIKU%2BPzXn%2FPz%2B%2Bv3NfT0lclvYpGkq%2Fkzvv5ZntBdEh%2FQB6AOk8Dy%2Fsea%2FD%2FeTr60VEeNdoWUZ%2FaWmZyB5QKl%2FxnqJymf2JqbwLf7pwM2pAwprtkcCJdDF%2FJxDzhLx%2BnPubnLM4cpkxpMCxdZtcDawqt7tz%2BBKOwFfRbjUDNAyTNgIgkHAKNgf4TpvVMTTlA9OVbnBiPk%2BtQdaJie24QZ3glUWUTg%2FmEaIR2QumlKugC6dK2ejOm1xBAYTio4toUzMZZsqAcRLceJ8CwgL3hI7w%3D%7Ctkp%3ABFBMwJT845pj
Yes you will need the crossovers, so you would need to find space on or inside the door to fit them. But why not just change them out for the Crunch component set: https://www.crunchaudio.de/english/DSX4-2E.html
They come with very compact crossovers which you easily place on the door and doesn’t require a lot of space. If you haven’t changed the rear speakers you could then use the ones you installed in the doors in the rear instead.
:thumbsdown: :thumbsdown:
