Hi All,
I have seen other posts on here about fitting one of these to a Z4 with nav, I have took the plunge and ordered one, I noticed in one of the AVINUSA photos it showed the new unit fitting better on the dash because you need to cut more away to lower it at the front. anyway i will update the post during the installation.
https://avinusa.com/10-25-multimedia-navigation-system-for-bmw-x3-series-e83.html
My current setup:
Factory high 10 speak sound system with amp
Factory sat nav with flip up screen
Factory TV hybrid unit
steering wheel controls
Factory bluetooth phone system
Aftermarket reversing camera in number plate surround
Intravee
Alpine 420 unit
Firestick running on the TV AV channel via a HDMI converter to RCA
Proposed setup:
Retain: Aftermarket reversing camera in numberplate surround, Intravee & Alpine 420 unit, I need the intravee to control the triple blink & flash to pass on my car.
Install 10.25" multimedia unit, carplay and android software to talk with ODB port. install platinumIPTV apk or mirror iphone to run TV
Add ID7 skin
Radio should still use factory head unit
steering wheel controls should still work
Factory bluetooth phone system should still work if not should work through new multimedia unit
My current setup:
Intravee
Alpine 420 unit
Proposed setup:
Add ID7 skin
