Hi all,
Odd one (well, I think it is). I pulled into Tesco about a week ago and when I turned my car off, the car made a beeping noise, similar to the noise to warn you you've left the lights on if you try get out with them on, and the oil pressure light popped up for a split second.
This is odd to me because it's like the car threw it up JUST as I turned the ignition off and then disappeared when the car turned off. It's done it once since, again at the Tesco car park. This is about a 2 mile journey and I'm thinking it could be something trivial as opposed to an actual issue.
I've ran an OBD check and nothing. There's no oil leaks visible on my drive where it's parked and the dip stick has the perfect level of oil. When this happened both times, I turned the car straight back on and the start up sequence shows all the lights it needs to and then they all go away, even the oil one.
Has anyone got any idea at all? It's very odd to me.
