Lower it until you can't get it out of your driveway... then you're good to go.
NeilP said:They fit fine with no issues. I needed a 10mm spacer on the front to clear the coilover adjusting collar. Unsure on a factory suspension setup.
Obviously you wouldn't be able to run balloon tyres either.
bradmarsh1989 said:Lower it until you can't get it out of your driveway... then you're good to go.![]()
Mr.Shanahan said:I'm going to be running a set of 18 inch. 8.5 front with 215/40/18 and 9.5 rear with 235/35/18 for clearance.
NeilP yours looks to be as low as mine with FK springs so maybe another inch..... Or two....... Or three![]()
