MrPT said:Pbondar said:On the earth in air, drag ruins it all as it affects the two identical objects of differnet mass (in BMWZ4MCs example) because whilst the drag remains the same for both objects gravity is acting on the heavier version with more force..that force overides the drag for a longer period than the lighter object of the same shape..
Ok, had a further think about this, and while I appreciate now that you can't ignore air resistance if you are having a freefall Z4 race off Beachy Head (with very good timing gear), I still don't understand the above.
Drag (force due to air resistance) remains the same for identical objects of different mass - yep
Gravity acts on the heavier version with more force - yep
That force overrides the drag for a longer period of time than for the lighter object - yes, but this only explains the higher terminal velocity, it doesn't directly explain why there are different rates of change of acceleration in the first place.
The acceleration due to gravity is the same as it would be in a vacuum (i.e. constant because mass nets out when you account for inertia). It's the effect of the drag force that causes the differing rates of change of acceleration. The force is the same for both objects but the lighter object has less inertia. Right? :?
The accelerative force due to gravity is the same, for a given point on the earth surface. The air causes drag and that reduces the rate of acceleration.
NB.. (Just out of interest. Did you know the heaviest you can weigh, any place on the UK mainland, is stood on top of High Willhays in Devon. Just please trust me on that one. It's true but it's been a long day.)
NB2.. The Z4 in the beachy head example. Should it somehow retain it's original mass after the crash. Would weigh slightly less than it did at the top of the cliff. Aren't you glad you joined the Z4 Forum now.
