Mavster said:I have them on order and that is the plan, I am wondering if it is worth doing however as the springs have made a difference
Mavster said:Hmm, I have ordered front and rear.....so, double the issue you mention, or will having front and rear result in balance restored, and so improved dynamics ?
Dont get the X5 link Mav, please explain? Also did you fit the eibach f+r arbs? And what concusions did you come to? I have active susp with eibach springs, an excellent choice if I do say so myself. Am thinking about new ARBs too and got a bit confused with all the info before. Bigger turbos is on the horize just wanna make sure the car can handle the power first. Thanks (did you see what l did there?).Mavster said:Ok got it. I did some research on this and the overall msg was that you will get much better handling until the (higher) limits are reached of the revised setup. I don't think many will reach those limits on street driving unless trying to outrun a Police BMW X5 on the local bypass (you see what I did there with the X5 link ? Lolz). :evil:
cheers for the update - Im going to order a set of eibach arbs..Mavster said:Hi, the X5 thing was a bad attempt at humour![]()
Yes I had the front and rear ARB's changed on my car at the same time as springs like you. The car now rolls much less than before on bends and on roundabouts I found
