WHich Roll bars exactly, can you place a link please?Player 1 said:I did roll bars first, followed by the M3 control arms a few weeks later.
I'd echo the effects Pbondar has already described. Makes everything feel much more stable and gives a lot more confidence in the car. It is a bit more jiggly on bad surfaces but is negligible.
The M3 components are a different prospect, there a bit more involved when fitting but the results are improved steering feel and a big improvement in outright grip as the wheels aren't deflexing under load as they used to.
Taking part in the bmw clubs Welsh Weekend a little while ago I could easily hang with the M3's and M2's in corners. The half hour or so a 35is was following me, I was pulling a good 3-4 car lengths on each corner. Throughly recommended![]()
mcbutler said:WHich Roll bars exactly, can you place a link please?Player 1 said:I did roll bars first, followed by the M3 control arms a few weeks later.
9designs said:Thanks for the info Player1, also caught up with your thread on PH. Sounds like a must do mod.
Any pictures of the head light levelling bracket you needed to make.
Bit confused over the links discussion, needing something else fabricating on the rear ? Then the option of parts from Turner ?
Are you going to ZedFest ?
9designs said:I found these, seemed to have kit purposed designed for the E89, plus other bushes and adjustment.
https://www.superproeurope.com/products.cfm?vehicleid=1433
The eibach pro springs, feel the same as OEM and won't spoil the ride9designs said:Was looking to keep OEM springs as I have the adaptive dampers and don’t want to spoil the ride.
Pbondar said:9designs said:I found these, seemed to have kit purposed designed for the E89, plus other bushes and adjustment.
Interesting...I assume these are similar to player 1 mods plus sort out the headlamp levelling issue..but they imply one kit for most EXX series cars and I thought the e89 was ‘handed’ differently?
Wonder on a 0-100 scale how much benefit comes from this kit and how much from their myriad of bush kits?
Player 1 said:Pbondar said:9designs said:I found these, seemed to have kit purposed designed for the E89, plus other bushes and adjustment.
That kit won't get around the headlight levelling bracket I'm afraid, the contemporary 3 and 1 series' had their level sensor on the passenger side whereas the Z4's is on the drivers side. The lower wishbones in that kit are the M3 parts, I checked European cars too thinking they might be the other way round but are not.
Here's what I wrote to a friend that was asking about the same thing;
''I made up a small bracket to fit onto the new wishbone but it really doesn't need to be anything fancy, the existing link is just clipped onto the wishbone so can be unclipped and made to fit the new M3 wishbone with the aid of a metal cable tie. Just make sure to measure the distance from the floor to the level sensor arm before dismantling as it'll minimise any need to adjust the headlight levels once completed.
That probably sounds like a lot but it really is a very simple job! The control arms themselves are dead easy to swap over and very accessible.''
I do also wonder how much benefit comes from the myraid of bushes, chiefly how much they will affect NVH as they all look to be poly bushes. The e89 already has an upgraded version of the e85's rear axle where most of the bushes are replaced with ball joints (same as a Z4M/e46 M3) except for two which I changed for Z4M ball joints.
The beauty of the M3 parts is that they are all properly developed by BMW and are easily replaceable when the time comes, NVH is barely impacted at all.
I suppose it depends what you want out of the car at the end of the day.
