Hi all.
Need some help on this. My drivers side head lamp washer jet is sticking up by about 3mm a bit like the pic on this link http://www.z4-forum.com/forum/viewtopic.php?f=2&t=23654&p=332620&hilit=jet+problem+a+bit+strange#p332620
However Ive poured warm water on it and it hasnt returned to normal. So I did a few tests today by removing the inner trim on the wheel arch and have found that they both are working but the drivers side one does not return to it's correct position. I then found that water is leaking from it also, as I can see through the access hole in the wheel arch. Its pouring from the top of the unit which i cant reach.
Im tempted to push the jet back down, but have also read this is not a good idea. So was wondering if I could pull it out to see if there is some sort of obstruction. But I dont know how to do it without breaking it. Has anyone done it without breaking it?
Any help would be much appreciated. Cheers
