Airbag light reset and replacement expansion tank
ERX
So I accidentally set off my airbag light the other day by reconnecting the battery while the seat was unplugged and I'm wondering what's the best/cheapest way to turn the light off. I bought a B800 tool but it doesn't seem to work on my car which is an 03 3.0i.
I also just wanted to change my coolant expansion tank to prevent any issues in the future, and I was wondering what some reliable options are in terms of non-OEM ones as the OEM one costs £91 according to my local dealer!
Any advice appreciated :D
Confirm B800 tool won't work - also bought one :headbang: but at least they're cheap.
Get Inpa set up on an old laptop - steep learning curve and you'll need a £12 cable from Ebay but I've used it a few times on mine now.
Other than that any dealer will switch the light off for a fee unless you can persuade them to do it as a freebie.
C110+ scanner from Amazon is cheapest if you want it to be intuitive.
https://www.amazon.co.uk/MAOZUA-Latest-Creator-Diagnostic-Compatible/dp/B011KMS2VA/ref=pd_cp_263_2/260-2187366-7022966?_encoding=UTF8&pd_rd_i=B011KMS2VA&pd_rd_r=d1c5f802-ead2-4902-8764-8916bc2a7ff7&pd_rd_w=wzB0f&pd_rd_wg=0psXw&pf_rd_p=01704ebe-a86a-4b47-8c36-0f9f5bbc2882&pf_rd_r=PC6E9MS3TPRGVHJW4E66&psc=1&refRID=PC6E9MS3TPRGVHJW4E66
The C310+ is slightly more money and offers some additional functionality
https://www.amazon.co.uk/Creator-System-Engine-Reader-Diagnostic/dp/B01MPZTM5Q
Either will work to reset your airbag light.
It might be worth saying where you are as someone on here local to you may have one.
I bought a C110+ last year, but haven't had to use it yet luckily!
But if you are anywhere near Sandhurst, Berkshire you'd be welcome to have a play with it. :thumbsup:
Thanks for the suggestions guys, I live in Bedfordshire.
Thanks for the offer :D I live in Bedfordshire, so if I'm ever down nearby I'll drop you a PM!
I'd be happy to reset the light for you using DIS/INPA. I'll be passing by on the m1 on 20th and 22nd this month if you haven't had the light reset by then.
I fitted a Hella expansion tank about a year ago. Covering around 10k miles without any issues. They usually go for around £40 (using discount codes) on GSF.
That'd be awesome mate, thanks. I'll drop you a PM. Sorry for the late response, I don't seem to get any notifications on here.
If you are fitting it yourself go with a BMW bottle. They slot straight on, aftermarket ones are often a pain to get them to fit on properly.
