airbag light reset
I'd be more concerned about why it's come on in the first place... It's there to tell you there's a problem with the airbag system - unless you've just had the steering wheel off for some reason and left the ignition on.
It very much depends what you've done as to whether it's an actual problem or not. Mine came on simply from taking the battery off and on!
I reset it using INPA / Tool32.
Assuming you find or fix the fault there is no DIY method to reset it.
Needs taking to a main dealer, indy or someone with proper software to code it.
I do recommend using INPA or similar BMW diagnosis software. First you have to read which is causing the airbag light, then fix the problem after that reset that light.
