ksher said:I think it will be extremely expensive to retro-fit sat nav (£3k plus). It is a £2k option when a new car is ordered. If sat nav is retro-fitted, a new dash board is needed first, with all wiring, labour, re-programming, etc. You better buy one that has factory-fitted sat nav (safer and better).
srhutch said:E85 or E89 a new ndah is not required, you cut a hole in the E85 as many of us have, or replace the storage bin with the monitor on the E89
£500-£600 DIY on E85
Very expensive on E89 as idrive also need to be fitted which will have to be coded no doubt.
srhutch said:Yes fitted myself, DVD drive £200 (real bargin), Monitor £115, Headunit £115, Loom £60, GPS Antenna £10, Original Map £20.
PVR and DHK have also both fitted, it's not hard but takes some guts in cutting the hole![]()
Details: http://www.z4-forum.com/forum/viewtopic.php?f=29&t=6067&hilit=sat+nav+retrofit+srhutch#p89945
