Doubt it will be the fluid causing the sponginess. It’s more likely to be air in the system, i.e. they didn’t do a good job of bleeding.
Common oversights are not bleeding both sides of multi-pot calipers and not going through a thorough ABS bleed procedure when replacing the pump and/or fluid.
