andre.zammit said:Leemarty6 said:Had this resolved in the end! The ABS module has been removed previously and someone installed the connections in the wrong order! so the front was the back and visa versa cost me a fortune to get this figured out and the car now has a brand new ABS module...
Hi again, so the ECU Testing path didn't work for me either. They said that my unit couldn't be fixed (and it suffered transit damage as well).
When you tried the used unit and couldn't code it, do you remember what the issue was? I'm assuming the inverted connections problem was on the new unit.
We assume the new unit didn't have anything wrong with it in the end and that it could not be coded because the connections were incorrect but well never know.
During the processes the ECU was re-flashed which opened another can of worms. I had to get a replace ECU as well because the original got fried in the process.
I had the brand new ABS unit coded with the connections round the right way with a 2nd hand ECU. many £££ later.
I would say to source a second hand unit online that matches the part no. exactly and have a reputable mobile BMW coder give you a visit.
