So i've that the 4 warning lights ABS, TPS and the others since Jan...
Clearing the old errors messages leaves just one error relating to the Speed sensor
I've already replaced the rear driver side drive shaft, its had broken CV boot for a while and it was more cost effective (approx £100) to just do the whole thing (perfect reluctor ring and cv boot)...in doing that we've also replaced the speed sensor with a new one (not sure if it's from Euro car parts or BMWs own)
They cleared the errors and I collected the car...and all was well...for about 5 mins and then then warning lights came back...
So, i'll pop back down to have the error codes read again and see what's up now...
Anyway, wanted to get your opinion as it seems a few others have been down this road...
Is it worth persevering with fixing the speed sensor error..ie getting a genuine BMW one in case the other one is shoddy...
or do I just go with the inevitable ABS module, ie the errors are a red herring for the module being borked...
The car drives fine and there's nothing else up, just wondering if I just get them to take out the old module and bite the bullet and get in touch with ECUtesting...
And just to make my wallet weep further...the Driver side window regulator gave up the ghost, left the window stuck at half open...so had that replaced / fixed with a new one while they were also sorting the driveshaft...£170 + fitting.
