I have a few issues that I wouldn't mind a second opinion on.
I have just racked up 34,000 miles, and am due a time based oil service (2 years). However I think the valve clearances need checking so have opted for an Inspection 1 at Darren Wood beginning of next month. The tappet noise reminds me of an old Talbot at 3k rpm. I'm hoping it is just clearances, and not cam or follower wear. At such low mileage it shouldn't be anything else should it?
Continuing on the noise related theme, I think I have a noisy fuel pump. At tickover it was noisy until I put some Seafoam fuel cleaner in. After 3/4 of a tank of petrol I can hear the pump when revving - quite a similar noise to the tappets. Is this anything to worry about or normal?
Final issue is a blowing exhaust. On start up and revving whilst stationary it sounds as if I have blow somewhere - hard to describe, but very much like a feint blow. I have had the exhaust pipe gaskets replaced, so its not them - I had it rechecked and was underneath when it was on the ramp. Has anyone had any issues with manifold gaskets failing?
I may be getting paranoid - I have just had to have a new gearbox on the A6 - that's after hearing a feint whining noise that developed, so seem to be listening for noises now!
