neilthomas
Hi all ive taken the headlights off the zed today to alter the wiring so that the flash works, ive tried mac's wiring but like he said the lights have to be on for flash to work,
so i was thinking about conecting the flash to the low beam which if i do will cause the back lights to light up when i flash, is this correct? so i was thinking if i put a diode in the low beam cable before i connect in the flash cable would this work? ive looked on ebay and found this doide does anyone know if it will work? thanks guys
FAIRCHILD SEMICONDUCTOR - 1V5KE12CA - DIODE, TVS, 12V, 1500W
Product Information
TVS Polarity: Bidirectional
Reverse Stand-Off Voltage Vrwm: 10.2V
Breakdown Voltage Range: 11.4V to 12.6V
Clamping Voltage Vc Max: 16.7V
Peak Pulse Current Ippm: 90A
Diode Case Style: DO-201AE
No. of Pins: 2
Power Dissipation Pd: 5W
SVHC: No SVHC (18-Jun-2012)
Body Diameter: 5.33mm
Breakdown Voltage: 12.6V
Breakdown Voltage Max: 12.6V
Breakover Voltage Min: 11.4V
Device Marking: 1V5KE12CA
Diode Configuration: Bidirectional
Diode Type: TVS, Bidirectional
External Length / Height: 9.52mm
Leakage Current: 5µA
Operating Temperature Range: -55°C to +175°C
Package / Case: DO-201AE
Peak Pulse Power: 1.5kW
Reverse Leakage Current Max: 5µA
Stand-off Voltage: 10.2V
Termination Type: Axial Leaded
Test Current: 1mA
Uni / Bi Directional Polarity: Bidirectional
Product Information
No. of Pins: 2
Test Current: 1mA
