Disca said:RubyBlueZ4MC said:Let's hope he doesn't stall Alpinas like he stalls ///Ms (twice![]()
Only because you can't park them
I did indeed go to see #255 this afternoon.
Nice car overall drives well.
Engine was cold when got there as advised, was stored indoors though so didn't have a warm-up period of longer than a minute or so.
Full service history with run in service done also.
The services were done pretty much bang on the two year mark each time with its Inspection 2 done in July.
Downsides:
- PDC has an issue but he said he'd fix that.
- Rain sensor on the wipers has some damage to the tinting. The wipers are fairly aggressive most likely as a result when on sensor. They were on non-intermittent when it was spitting.
- Visible in picture 5, the drivers side door sits out about 1-2mm from where it should yet all the bodywork panels line up correctly, could just need adjusting.
Was offered 7k p/x for my 2.0i 08 52k.
Doesn't sound too bad then - warm-up period sounds about right, mine is kept garaged and the engine note settles in under a minute
Birds should fix the PDC and the door alignment prior to any sale - as far as the rain sensor issue goes, the worst case would be a replacement windscreen and that's a bargaining point as they should be able to do that a lot cheaper than an individual would. What sort of warranty are they offering?
Did you get a chance to open her up to test the performance?
and, remember that's their first offer... if you're still interested, a bit of negotiation should get you a better deal as long as you don't appear too keen and require 'persuasion' to get you into the car
