v8z4 said:HECK YEAH! I did some measuring tonight and the LS6 motor mounts are in the EXACT same location (front/back) as the BMW inline 6 motor mounts! No funky motor mounts needed!
Score!
v8z4 said:Well.... update/plans change..... no more supercharged 383.........
v8z4 said:I already have the M3 rear rotors (and calipers) on the car from when I did the M3 rearend swap.
The plan is to wait it out and find a good used set of 340mm CSL rotors for the front. Then I'll go get the Porsche 996 calipers front and rear.
I'm in the middle of (almost done if I can find some time between work, school, and family) converting to a GM Hydroboost (hydraulic booster from a 3/4 Tahoe) and C5 Vette master cylinder.
pokeybritches said:v8z4 said:I already have the M3 rear rotors (and calipers) on the car from when I did the M3 rearend swap.
Will the 996 calipers not fit the Z4M rotors? They are 345 mm.
http://www.turnermotorsport.com/p-1518-cross-drilled-floating-brake-rotors-front-e46-m3-cslzcp.aspx
It was my understanding that the Z4M has the M3 CSL calipers and rotors.
