PAH said:Ok fair point.
2 prices on ECU site £250 refurbed £200 own refurbed approx.
If i buy ready refurbed to bolt on it would need programming by BMW but my own won’t?
I emailed for a quote,Clobber said:Zed shed will fix yours while you wait and modify it to make it more serviceable in the future.
Yes I did read this and if problem persists then they or Zed shed will repair it.Rucky said:If you have not done so already - I pulled this from ECU testing Cardiff site which explains the faults and causes - it's a very concise . The ABS / DSC computer controller sits on the Pump and is programmed to the specific vehicle.
https://www.ecutesting.com/common-faults/bmw/bmw-abs-dsc-pump-common-5df0-5df1-fault/
Let us know how you get on, not sure how many times you will get away with tapping the pump motor?
Jameszy said:PAH said:Ok fair point.
Depending on where you are in the UK (South), there are garages that do a same day turnaround for removing, refurbishing and replacing the unit (including sorting the brake fluid).
Let me know if you are interested
Wylie1 said:Jameszy said:PAH said:Ok fair point.
I would welcome any recommendations to get my fault code read and whatever it throws up repaired quickly. Murphy’s Law my lights have lit up just before my MOT is due!! I’m based in Bromley/ Orpington area
