Jfgoldfish
I have noticed my zed idles at a fairly high speed. Is 900 - 950 rpm normal when hot?
If not what might be causing it to idle high? Vacuum leak?
I plan to replace the vanos solenoid seals that are seeping a tiny bit of oil since they were removed for cleaning. Would the inner oring passing oil cause high idle?
The vacuum pump is also needing seal replacement, doubt these could be related?
Thanks all. Hope you are enjoying your valentine's this evening :wink:
