simvaughan1 said:They look great! Pictures when you get them on the car!
Couple of questions though, as I'm currently in the process of doing a set too:
After you had stripped the paint/corrosion with that prep wheel, what did you use to smooth it off? My thoughts are sanding by hand is going to be a pain!
Did you paint the basket or is it polished/lacquered?
Did you paint with rattle cans?
Cheers![]()
I used a detail sander and different grades of grit on a couple I had to resort to some primer putty paint to get a decent surface. Some indentations are still visible as I got bored and tired of the whole job. I could/should have spent a bit more time.
All painted and lacquered, they would probably benefit from a good polish before I start using them.
Yes rattle cans. E-Tech wheel paint and lacquer.
Andi.
