Hall Sensor 54347190735
NS66
Seems i may need to replace a hall sensor and looking on the forum the E88 version 54347190735 is suggested - old threads I know and suggest around £20-£30 however my searches are showing £100 + is this just shortages or profiteering?
Any one know the best place to get those from currently?
TIA
TIA
BMW profiteering
Sadly I don’t know of any other options
I got 2 spare hall sensor with a ram for a Toyota. For £20 few years ago. Also from LLL for a Mini about £15.
So try to be creative in your search.
Seem to used on a lot of cabrio's, Ferrari, Lambo, Toyota, Mini, BMW. Also Jaguar and Audi.
Try breakers.
But do you really need to replace the sensor.
How many actually fail.
Are you just taking what a obd reader tells you.
Might be just a broken wire or bad connector, my car has had both.
I got 2 spare hall sensor with a ram for a Toyota. For £20 few years ago. Also from LLLR for a Mini about £15.
Try breakers.
Thanks - I’ve had a search on mini ones but also seem expensive as well. Will keep searching, not totally desperate yet 👍🏻
Prices utterly ridiculous for something with £1 of parts inside.
Someone needs to reverse engineer with a 3d printed housing.
The chip inside is well known. The magnet seems to be the more complicated part of this assembly;
Developing a 3D housing should be possible.
Probably need some experimenting with alternate magnet.
I also have one taken apart to experiment.
The dimensions of the housing are a limiting factor. And in fact, the special format of this magnet, I can't imagine how to produce.
Try here:
I ordered some during the week and they are due to arrive via Fedex early next week. $40 to ship to the UK but if you are buying 2 or more they are still cheaper than alternatives here.
Thanks - says currently unavailable ?
Oh dear. I may have got some of the last ones. I think my issue is the microswitch (replaced it today and things worked but only for a while, but I think my crimping is the cause, so will need to revisit it next weekend when I have time). So if I have a spare hall sensor - which I expect I will - I will message here.
Thanks so much that’s very kind
Hope you get yours sorted
