Fault 5A53 : Transmission overheating, phase red, black
Christopher72
Active member
 Ohio
This hit twice this week iu 75F weather on a light drive... So... :poop:
I have an indy that is going to systematically check temps to trace the problem next week, but ugh.
I've done transmission service 2 years ago, it tripped in july last year and the stealership just cleared the codes without any work on it.
Hopefully this wont be too painful.
Usually it’s a low fluid issue..or just occasionally a rogue ‘blip’
Update: 5A53 Transmission Overtemp Fault — Finally Getting Properly Fixed​
Been chasing a recurring 5A53 (Phase Red/Phase Black — Transmission Overheating) fault on my 2011 Z4 sDrive35i (E89, N54, Getrag GS7D36SG DCT). My local BMW dealer kept clearing it without pulling freeze-frame or shadow fault data — so naturally it kept coming back.
Took it to a European specialist running ISTA+ and they actually did a proper root-cause workup. Turns out the culprit is the combination RPM/Temperature sensor (p/n 28107842851) — one unit that reads both input shaft speed and fluid temp, and it lives deep in the bell housing. When it starts drifting, the DME sees overtemp conditions that may not reflect actual fluid temps, which is why just clearing the code (or even a fluid change) doesn't fix it.
Getting the sensor out means pulling the transmission, so while it's apart I'm doing a full service plus everything you'd be crazy not to do while you're already this deep:
Transmission service (primary repair):
  • Combination RPM/Temp sensor — p/n 28107842851
  • Clutch cover seal — p/n TBC
  • Inner shaft seal — p/n 24137546665
  • Pentosin DCTF-1, 7 liters — p/n 83222147477
  • Internal oil filter — p/n 28107842828
  • Pressure filter repair kit — p/n 28107842840
  • Sucking jet pump (scavenge pump) — p/n 28107842838
  • Oil pan — p/n 28108070791
  • Oil pan bolts ×14 — p/n 28107842386
  • Fill plug — p/n TBC
  • Misc gaskets, hardware, seals
Preventive driveline work while accessible:
  • Harness connector O-ring — p/n 28607849555
  • Transmission mounts — p/n 22316799331 (×2)
  • Flex disc / guibo — p/n 26117610061
  • Guibo bolts — p/n 26117527475
  • Guibo nuts — p/n 26127536563
  • Center support bearing — p/n 26121225071
  • Center support carrier bearing — p/n 26127572932
  • Propshaft repair kit — p/n 26117567770
  • Propshaft rubber boot — p/n 26117526628
  • Propshaft damper ring — p/n 26117581110
  • Front driveshaft bolt — p/n 26117635643 / nut — p/n 26117523709
  • Rear flange bolts — p/n 26119454792
All-in quote ~$4,892. Steep on the surface, but the bell housing labor plus a comprehensive driveline refresh justifies doing it all in one shot.
Main takeaway: if a shop clears a DCT fault without diagnosing, walk away. You'll just be back in a few months.
Will post an update once it's back on the road.
Finally in the shop this week after waiting for German-shipped parts... My son has taken over that garage bay with his 2015 F30, finishing up new tips on a Valvetronic axelback. Certainly makes that N26 purr. Zed withdrawl continuing.
"Several thousand dollars later...."
I 'm picking her up tomorrow, I'll share the number of pain when I see the invoice. Looking forward to getting a little more driving in before the season is over..
Mechanic said that the Meyle Cartrige filter came apart when removing... replaced with BMW Getrag.
This was all for a stupid failing sensor... :oops: Hopefully hasnt missed a bolt.
View attachment 299439View attachment 299440View attachment 299438
Well will love to know ALL the details!...my mystery leak over 2 years, 3 oil pans , countless litres of DCT fluid was a poor o ring on a cheapo pressure filter cap!-;)
So it's back, and feels like a new transmission. Buttery smooth now. Night and day. If it drives like this for the rest of its days, it's worth the work.
And, hopefully, the last time its touched. He put some miles on it in running diagnostics for the phase red and black.
Labor Total $2,160.00
Parts Total $2,445.76
Total Subtotal $4,605.76
