Can you identify these 4 cables? 2 on each side near seat belt mount.
Vanne
Senior member
 Dubai
Hi guys, stuck pretty deep within the roof fix atm, but something isn’t right. The rear quarter windows don’t operate..
I’ve had a look back there and I found this, right where the seat belt mounts are. Are these anything to do with the windows or is there supposed to be something else up near where these wires are that they connect to?
Pic is worth a thousand words right..
Right side near where the seat belt retracts into.
Left side where the seat belt retracts into.
This is where they lead to in the boot, just past the rear shock mounts.
I initially thought they might have been from a sub woofer or something like that, but now that looks doubtful?
Any ideas what these are for guys?
That sounds promising.. Not so promising is that they are quite defty wires, so we talking amperage.. I hope they didn't rip there from the hydrolic ram actuators..
Do you have access to TIS or ISTA ..the colour codes on the wires should show what they were if they are factory ..which to me I’m not so sure..
Thanks for the diagram, again appreciated. I do wonder what these are then.. while I was flying to Islamabad , was thinking, is it possible they are from the AMPlifier?
Okay found em… and guess what.. they are the rear quarter window power wires..IMG_1886.png
Blue/red and pinkish/yellow.
Sigh.. a well at least we’ve identified the cables.. this is the right side.
Quick question, can I access the motor with the roof closed?
And then I figured it out. They are indeed the rear window power wires.. found the leads hidden inside the window cavity..image.jpg image.jpg pics of the wire and where the rear window is attached to.in the rear wheel well..
Don't know of i missed it but any idea why the wiring has been butchered so much all through the car?
Its like it's been done maliciously.
Absolutely no idea mate, I bought it with a blown turbo and boot/roof not opening for the last 5 years. Unregistered, due to the rear tail light right hand side being blown, and unregistered as they didn’t know how to get into the boot to change the globe. It looks like to me they tried to gain access via the ski hole.. which is impossible.
Whom ever they sent the car to to get fixed, wasn’t obviously bmw versed.. there was nothing wrong with the turbo, just the waste gate was completely incorrectly set, and I had the boot open in like 5 minutes (with doing some reading on here (great website this forum) and excellent knowledge from the guys/gals on here)
After a good night snooze, I can kinda puzzle together what may/may not have happened..
Car presented with a roof issue/ either a micro switch or hall sensor problem, didn’t know how to fix it, possibly the rear windows were stuck down, (68D will do that) so they cut the wires and used a other power source to put the rear windows back up. And left it like that.. that’s what I think..
So I’ll attempt the opposite , I’ll lower the rear windows and then reconnect them back up to the system. That should put us back into the regular loop of fixing the roof.
  • Wow
