Power-fold mirrors - pre-wired on February 2004 E85?
Oh man, I wish my rear view was auto dim -- that would be sooooo helpful.
So even if I do find an auto dim rear view and driver side, I wouldn't be able to use them b/c I don't have the wiring in there?
The chassis of the car will have all the wiring for dimming mirrors all round. The actual door should have the wiring but its not guaranteed. The door mirror unit will not have the wiring.
Oh wow, even the rear view mirror? So I should try to search for donor parts/ebay a mirror? Is there a guide on the installation?
Getting You Tubing definitely stuff on there it’s not as hard as it looks just knowing the order and being a bit careful worst you can do is break a clip really so buy a cheap bag of spare clips before you start
I’ve managed to pick up a pair of OEM 9-wire power-fold mirrors, so I’m getting everything together before fitting them.
My car is an early E85, February 2004 build.
Before I start stripping the door cards, is there anything you’d recommend having ready apart from a few spare door clips? I also bought the correct window switch.
Do I need to source the separate power-fold mirror module, or is it controlled by the GM5 on my era build.
So far I’ve been quite lucky with factory wiring. The other day I noticed my car already has the loom in place for the parking sensors too
Thx 😊
Thx 😊
Keep your old window switch as a spare. They are all the same, just need the correct trim cover and the button pushing in to the slot that is already there.
