Reviving a Neglected Z4MR
0l0dom0l0
I've been around on the forum for a while but never properly introduced myself - so here I go - complete with my story of how I became the owner of a very neglected 2006 interlargos blue Z4M...
Back in April 2025, I took a punt on what was, and still has been, the cheapest non category/ write off Z4MR that I've seen to date. Naturally, the car had heaps of interest, despite the awful eBay photos and the several declared issues in the advert. I was in Oxfordshire at the time, the car was in Southampton, so not too far away. A phone call to the seller later, I sent a holding deposit (without seeing the car) to secure my interest and headed down the next day to view the car with the intention of bringing it back with me.
Upon arrival, I was greeted by a nice chap called Paul, who had been the owner of the car for several years and done about 2k miles per year in it. Paul referred to himself as an "enthusiast" and I could tell was a genuine guy. I got the feeling he had spent a lot of money on the car over the years and had simply got to the point where he'd decided that the car had started to become more hassle than it was worth.
The car was filthy and had not been cleaned, it looked tired and tatty and the dash was lit up like a Christmas tree.... Perfect!.... Just my kind of project.
Several things stuck out at me:
Cosmetics
  1. The front bumper bracket was broken
  2. Bumper was scratched and a bit of a mess
  3. Missing headlight washer cover and washer insides
  4. Headlight was cloudy
  5. Roof mouldy
  6. Wheels lightly kurbed
  7. All badges faded
The car had a fairly complete set of history for it's 112k miles, no rod bearing or vanos work had been done (we'll get to that later), but a recent inspection 2 service had been completed along with a replacement front tie rod, complimented by a long list of "recommended" additional work.
  1. TC/ abs/ brake lights on the dash
  2. AC not working
  3. Diff input seal leaking
  4. Exhaust hardware failing
  5. Front left brake caliper bleed nipple broken
After a quick test drive with Paul at the helm, I reluctantly handed over the money and headed back in the car.
IQRRzODf8w1qTKt-EQo1j6_XATiSks2wX6bmFjN4YE81PoY
On the drive home I was immediately disappointed, the car was handling like a bag of s***. The steering wheel was at about 2 oclock and the throttle had this weird delay where it continued to accelerate for about 0.5 second after I'd lifted off. It was strangely off putting and distracting and took all the enjoyment out the car. It seemed very odd to me as everyone raved about the sharp and precise throttle control on the S54, something was off.
Instantly regretting my purchase, I set out to try and tackle the various issues on the car....
A/C
The first thing I decided to try and rescue was the A/C. When diagnosing any A/C issue, the best thing to do is try and get the system recharged - you get a free diagnosis. If there is a hole in the system, they can't charge it with gas and will turn you away (usually FOC). If the system passes the pressure test then you can normally get an indication on the system health by the remaining gas level in the system - gas left usually means it it just low, no gas but it passes the pressure test means it may still have a small leak. In my case, it was just low on gas, so an hour later and the A/C was working, result!
IQRS1ecyAIT9R5S5UuK30lVVAbhBVRq0bY2rHgPGRqdiCDI
Cleaning...
Inspired by my success with the AC, but equally embarrassed by the state of the car, I couldn't stand looking at it anymore and decided to clean it next. The photos make it look better than it was, and hide the full thickness layer of grime on the steering wheel that became sticky when it was touched :sick::sick:.
IQQZ6r2LTTDQSpCi4p3e5peKAaZ26xiReyY_RoV843ISb64
IQRJmzX7iaCgQ54TF19bKx18AYoc_-olAPQOOQowvIe2Mwc
IQT4zjBHibaETaly2qaPtiGBARfZY3kheKy_F8YhVmM2oGg
IQRnV1skTmd9QKZeoreJSUifAW89cBDYHzxAhGjdwefKKl8
IQTTeagMV78NQZXfJ2atOE-tAZmP2t4vPX9uUe69P9plC2Q
IQSiFxoiwJAJT4_IjHDe2QBUAZKN-mO8VSJoXVxiYw2rK2k
IQQph_ydhSDhRJuqpCKJC3IRAVKgzV73HFzBfemy_nJHItE
The roof....
The roof was actually working which was a nice touch, but it was imbedded with algae and let the car down. Most people say that you need to re-colour the roof when they get old. I had my reservations and was concerned that any re dye attempt would leave the roof looking patchy.
I employed some autoglym soft top cleaner with a soft brush on a drill and was disappointed. Despite cleaning the roof several times, I was unable to shift the algae. At this point, it was clear something more industrial was required.
So next attempt was to use the soft top cleaner and brush and rather than rinse, I decided to carefully pressure wash off the roof (against recommendation). I could instantly see the algae disappearing and knew that this was way more effective. I left the roof to airdry and was pleasantly surprised by how much fresher it looked. I continued and applied the re waterproofing liquid. That was the roof sorted.
IQRWDXrALDN7RJ-c8U8W7PpzAU8Tp6olmUcRCTKx77quW7A
IQTj0uV7duECQb_ZXNNd7l-gAVV7r86IluK6EcM4Idc5rXU
IQS5Jqc_raUjS5nsC_HhBumzASRYC3r4dRU2Bzz30mr4YY4
IQR3XeRU3yUlS7sWv5Ob3H_QATrkscaUtws9xnaLqYs-x9w
Christmas came early.....
So with the cleaning out the way, the next thing I wanted to address was the christmas tree dash.
When buying the car, I had scanned the car using Carly and noticed that the ABS module was complaining about the steering angle offset. The car had had a replacement track rod with the recent inspection 2 service, given that the work had been done at a well regarded specialist, I was a bit confused with a couple of things.... why had only one track rod been replaced, and why had the tracking not been completed after this work?
Clearly the alignment hadn't been done as the steering wheel was off centre at about 2 o'clock to go straight, confirmed with no mention of wheel alignment on the invoice.
Anyway, at this point I took the car to have the front toe adjusted. Before sinking £100 on a new track rod so that both were new, I wanted to see if the wheel alignment was indeed the cause of the christmas tree dash. After an hour or so at the garage, I had confirmation that the front toe had been adjusted and the steering wheel was now straight. They had been unable to adjust the one that hadn't been replaced, which was to be expected but the alignment was good enough that the wheel was dead on centre.
A fault code clear with Carly, and an ignition cycle later, the christmas tree lights had gone out! Winner!
More importantly, the weird throttle delay that was absolutely killing the car had also gone away which must have been part of the limp mode the car was in when the dash was lit up. Double winner!
I felt like the car was now safe enough for me to have a proper drive through the Oxfordshire countryside and see what it was all the fuss was about - and this was the point that changed everything for me. The engine, the noise, the roof down - I just had this moment where I said "why didn't I get one of these years ago??".
IQQOGtZ1XE5lRphGX6-Q2ddJARBpOdlZtZQMzr7yZ4-u2uM
I wish I'd never started...
With the cosmetics now in reasonable order, my eyes were continually drawn to the poor state of the wheels. While the curbing wasn't too bad, the paint was flaking with visible corrosion underneath. Up on axle stands to get the wheels off, which would also give me a chance to tackle the other track rod while I was waiting for the wheels to come back...
IQQ9jG6kfEtiTrYQH16ukEQYAc0wm4GLbQU6-AAWHidR_YY
IQQXjqh35nxXSZzHKHfuELH6ASQPHBbpToig2fPpdWxAu4A
With the wheels removed, I'd noticed all 4 bump stops had been completely destroyed. I also noticed that paint on both the front and rear springs had started to fail. A quick google revealed no cheap replacement parts for the Z4M suspension, springs/ dampers etc were not available OE and BMW were eye wateringly expensive. I therefore decided to remove the springs and take them to be powder coated with the wheels while I waited for the new bump stops and top mount bearings to arrive from BMW.
I'd also placed an order for several other parts:
  1. Rear trailing arm bushes
  2. Brake caliper bleed nipples
  3. Replacement headlight washer and cover
  4. Complete tie rod and dust cover
  5. New centre caps
  6. Wheel bolts
  7. Rear top mounts
  8. Replacement ashtray
  9. Rear diff seal
  10. Replacement gearstick
  11. Exhaust hangers
  12. Rear brake lines
  13. Gearbox mounts
  14. Prop doughnut
  15. Engine mounts
RTAB
These had been advised by the specialist, despite in the end being there being nothing wrong with them. Fitting them was straightforward using the tool. Remember to follow the BMW instructions for tightening them to the cup so you get them set to ride height.
IQT36hc8m79yQa-9X3gNgrKMAUSXBibuCrqbpi7b_EJtX64
IQSA2NrByvfERp3JaK5f_0vJAT1wsAMPXWSDi0ys_m-TeW4
I'd noticed that the rear antiroll bar drop links were split, I tried replacing the drop link in situ but it was impossible so I decided to remove the rear antiroll bar. This meant I needed to drop the exhaust - not a big deal as this was going to be needed for me to replace the leaky diff input seal.
IQQdhguintr3QZN81gczOUDcAezna8orwbD6iJlr9QQ9f8U
Removing the exhaust had had an unexpected side affect, the front flange that bolts to the downpipes fell off! Another thing to add to the list....
IQTXktuCKsA5TKLXhbX0QBolAT7AxBh10XMb1UxkGnUC7sk
Removing the exhaust had also revealed some other issues, my front downpipe was unfortunately cracked. This needed to come off to be repaired.
IQTWagSx74zdR4UE8T0FORCuAQVCa8-IOQIcLuMlQLXY0ts
With the propshaft removed, I decided to replace the centre shaft bearing while in there. The original was okay, but just more of "do it while you're there".
IQQdBZqjT7LUTI7j1O2fuk9MAV5MaysmBDBf6_4DoObcPKU
IQRyGysLxH4kSZyoTS_8xS_1ARlzY9BXnYE4T4BkImcg7G0
