Been asked for help with an M54 2.5i. Aircon was working fine until about two weeks ago. Then it stopped getting cold.
Owner has just had it completely checked over, emptied, vacuum tested, refilled but still no cooling going on.
The pipes in and out of the bulkhead both remain at an ambient sort of temperature, whereas I'd be expecting one cold and the other hot.
The fan kicks in ok.
When you select the aircon on you can see the pulley engage and spin on the compressor. This tells me that the pressure switch is working and telling the magnetic clutch to engage.
So, what is left?
Is it possible for the compressor clutch to engage but somehow for the compressor not to function correctly?
Or is there possibly another issue somewhere?
@Pondy - have we finally landed in your area of expertise?
So, what is left?
