What's the plan with the MHD Adapter? I didn't realise they supported the N20, or is it possible to upload someone's remote tune with it?While replacing the rears with the b12 combo kit, came across this..
Brake pad indicator a shot duck, and the abs sensor doesn’t have a screw in it.. think I’ll replace both while iam there..
More dodgy sheit.. looks like someone rooted the socket. ..
Looks similar to the proper spec one..(new one on left)No plan really aside from using bimmergeeks protool to check the functionality of the hall and micro switches. I could have easily used my Insta lappy, but this is easier.. I like easy…What's the plan with the MHD Adapter? I didn't realise they supported the N20, or is it possible to upload someone's remote tune with it?
Looks like new light(s) time imhoSigh…. While I was swapping the upper rear shock mounts, thought, might as well have a look at the reverse nd brake light not working.. hmm.. replaced the reverse light no issue, but the inner brake light has melted.. pretty sure the bulb is still in tact, maybe that’s why it got through the mot, but that’s not good, looks like I’ll need to replace the whole light as it’s melted the rear housing around the rear brake light.. sigh..
But it will need to wait, I’ve removed the inner brake filament, as I’ll need proper access with the boot open the other way to fix this properly. Hopefully I’ve isolated the light, I’ll check when I next start the car… so I’ll need to fix the roof first.. bloody hell....
Maybe no so bad after all, the outer brake light still works and I can code out the inner one.. will see.. or might just get a new light.View attachment 297482
I forced the bulb holder through the middle bit to give me some more length to work on it to remove the filament. You can see even the holder has gotten way to hot.. wonder what spec the bulb is..View attachment 297483
Zero identifying marks.
View attachment 297484Looks similar to the proper spec one..(new one on left)
Typical problem is the red tint in the lights fades ..so a new one on one side looks much stronger red than the old one…Lots to do before we cross that barrier Pete, but yeah I’ll keep a look out for a set/single. Pretty stoked, just finished 12 install.. and torqued the control arms bolts with weight on wheels.
Now just gotta put the license plates on and then go get an alignment..
I use a series of axle stands for the discs to sit on to get proper ARB / steering linkage aligmentCheers, yeah I’ll keep an eye open for em. Just got back from the alignment, and no you can’t tighten the stuff up on jacks trying to simulate weight on wheels, just not possible. It took me like 15 minutes under the car at the alignment joint while it was on the lift.
Waaay out of spec .. everything, but slipped the guy an extra 100ead and he did a grand job, and didn’t mind that I was doing stuff as well.
I just came back from taking the missus on a date night, we had a few things to celebrate, didnt take the 28i, but the tundra, but as i walked back in the garage, i gotta say, its sitting really bloody low at the back, prob too low... ill look at it tomorrow, otherwise ill be swapping the rear springs back in that were in there when i got it. might even consider swapping the front springs back in too.. ill give it a few more drives...Default (prior to muppets coding) is one touch does 3 links, full prod stays on, never been a fan of B12s.(eibach springs designed for decent German roads) .for Scotland very inappropriate IMHO..if its car that only goes out on well made roads on sunny days..maybe..stock springs or msport springs with B6/B8 different ball game..
N20 in 28i guise especially remapped can be very nice..mine was at 305bhp and a flat torque curve could easily stay with any stock E89..
Not one of my greatest decisions to part with it..
