Fuel pump
MikeyH
Elite
 Devon
Hello people, How easy is it to replace the fuel pump on an E85 2.2i. I'm assuming that it's broken as when I turn on the ignition it makes a load droning noise for a few seconds and them carries on when I start the engine. :( Pelican Parts gives it a 5 star difficulty rating and looking at the "how to do" I think it's beyond me. Just hoping it looks worse than it is. Thank you, Mike.
@Liam22 just did the one on his son's car (@Max Crilly), so he can give you the most up to date advice.
I refitted my petrol tank on Friday, and to access the fuel pump you need to remove the exhaust. This isn't hard (assuming the exhaust isn't rusted), but you'd need to be confident.
It's the same as this guide for the M versions. I don't agree it's a 5* job, personally, but probably best not to start if you're not confident imo as it's an ubdrivable car if it goes wrong
It's easy enough I didn't bother replacing my functional fuel pump preemptively before refitting the tank, which I would have done if it was going to be a nightmare.
Thank you Triggerfish, I hadn't read the 'how to do' closely enough, it's beyond my skill set.:(
@MikeyH - if you're getting it done then probably worth getting the rear brake pipes checked while they're under there with the access to change them.
Yes, thank you I will. :thumbsup:
They're very likely to be past their best if they are the originals. My 2006 car is going in to get them replaced tomorrow. :(
Took me 3 goes to get it right!
First time the float (fuel level sensor) got stuck so didn't show anything on the fuel gauge.
Second time I didn't reattach one of the internal fuel lines correctly so it was just spraying fuel around the tank (and no start). This was *after* I had refitted the exhaust!
Third time I got it right.
Race car has started throwing fuel pump codes after running dry so I reckon I'll get it right first time on that!
Got a local mobile mechanic arriving on the 16th to look at it (diagnostic) and then change it on the 19th. Made sure he knew that the exhaust needed to be removed, he did. The other one was put off a bit so skipped him. No Z4 for a while :mad:
They don't seem to be a common failure. It may be more prevalent in cars where the fuel level is allowed to drop low enough to pick up sludge from the bottom of the tank? (Just a theory, not a fact.)
I've never let mine drop that low the wife moans about getting stuck out somewhere miles away. Since the the fuel price hikes I refill when it's down to just under half way. :thumbsup:
Chuck a bottle of Redex in the tank and see what happens. My pump is noisy but Redex sorts it our for almost a year at a time.
Mine is very noisy, is it easy to get to the filter? It seems it is accessible from the boot but with a lot of removing of bits and still draining the tank. I don't understand why it is still working as it sounds like a train coming up behind me. 😱
The filter is in the tank. The only access hole to the tank is the one with the fuel pump. Sadly, it is not accessible via the boot.
