Painful?
Painful?
Got to get mine done next weekReplaced the differential output shafts
Pretty easy, with the diff removed!
View attachment 294243View attachment 294244View attachment 294245View attachment 294246
Got a picture of what this is?Need to order a new bumper support trim to hold the bumper better.
It clips in under the front wing, and secures the front bumper corners. Not cheap about £33 each from BMW.Got a picture of what this is?
I picked up some of these from AliExpress, £15.39 for the pair and they’re pretty hefty so I think they’ll stand the test of time. Getting the old broken ones out was the biggest problem!It clips in under the front wing, and secures the front bumper corners. Not cheap about £33 each from BMW.
Thanks, in my head, your wording made it sound like something far larger than what it is.It clips in under the front wing, and secures the front bumper corners. Not cheap about £33 each from BMW.
I think they came via me in Sussex today where I sorted @jasecasecarr ’s airbag coding.Replaced the differential input shaft, stripped and cleaned the CV joints on the driveshaft, ready to regrease and replace the boots. And then painted the differential in rust converter
View attachment 294428View attachment 294429View attachment 294430View attachment 294431View attachment 294432View attachment 294433
Also collected some parts thanks to a very generous act by @Umfaan and his friend, Jason (who maybe on here?). Thanks both!
Nice job, what’s your technique for tightening up the leather?Seats were looking a little saggy and worn.
So I managed to stretch the leather to remove the creases and apply some fresh Imola red dye, after stripping off the original coating.
Just waiting 24 hours now, so I can apply a coat of satin clear leather sealant.
Need to do passenger side yet. Work in progress.
(I know the panel behind passenger seat is cracked - I have a new one to fit later).
View attachment 294190View attachment 294191View attachment 294192View attachment 294193View attachment 294194
Yes, he did!I think they came via me in Sussex today where I sorted @jasecasecarr ’s airbag coding.
Heat gun low setting, circular motions, slow and steady, just let it build up heat gradually takes a solid 5-10 mins. Don't get too close or you'll burn it. Once it hits 100'C the leather tightens up and pulls out creases and sag. Once it's done, let it cool, then Repeat as they'll come back ever so.slight. once it's cooled, add some leather conditioner to keep the leather soft but tight.Nice job, what’s your technique for tightening up the leather?
