Good to know..in what way?The new engine mounts actually made a substantial difference.
Later this summer new front tires, sway bar bushings and maybe tie rods (if worn).
FWIW it’s not a great idea to fit mis matching rolling circumference tyres…the stability control system can’t cope with large dissimilarities..resulting in unpredictable results just when you need it..And they’re on!
In the end I opted for Goodyear Eagle F1 Asymmetric 6 tyres in 255/35/19 and 235/35/19 configuration. The whole set were just over £500 from National Tyres with a code.
Very happy with fitment after lowering her down and giving her a quick turn around to settle things a bit. I may need to reduce the rear spacer size a smidge (currently 20mm) but we shall see how I get on.
Otherwise there appears to be plenty of clearance elsewhere.
For reference, I am running Bilstein B12 suspension.
View attachment 293459View attachment 293460View attachment 293461View attachment 293462View attachment 293463
Damn it. It would have helped if I’d read my research properly. Turns out I should have bought 245/35 for the fronts. Oops!FWIW it’s not a great idea to fit mis matching rolling circumference tyres…the stability control system can’t cope with large dissimilarities..resulting in unpredictable results just when you need it..![]()
There are no specific documented and agreed limits..the generalised advice is to keep it with 1%…I know for a fact that at 3% that it doesn’t work..found that out the hard way..later post DSC 60E versions had different logic…Damn it. It would have helped if I’d read my research properly. Turns out I should have bought 245/35 for the fronts. Oops!
-2% difference on this setup. Retrospective research suggests this is within the margins the DSC system can deal with.
Yeah, you’re right. There’s a lot of anecdotal info out there on percentages and learning ability of the DSC system but again, it’s anecdotal.There are no specific documented and agreed limits..the generalised advice is to keep it with 1%…I know for a fact that at 3% that it doesn’t work..found that out the hard way..later post DSC 60E versions had different logic…
It’s up to you what you do..I’m posting it for others who may see this as good practice ..which it’s not..
I never had any problems till the one day when I deliberately provoked it..it then did a 270 degree spin with all the warning lights on..Yeah, you’re right. There’s a lot of anecdotal info out there on percentages and learning ability of the DSC system but again, it’s anecdotal.
I’ll run this as long as they’re legal and make the switch to something as close to 0% when they’re worn down.
I’ve also learnt that there’s more room to play with than I envisaged, due to the divorced shock and spring setup on the rear axle.
Anyway, all purchases for another day, providing there continues to be no silly DSC behaviour on a daily basis.
I'm happy giving E89's some love.As the name states. There is an E85/6 one of these but not for E89.
Have just put mine under cover and on trickle charge whilst the snow ice and salt get to work.on the roads
Am I allowed admitting jealousy; great color choice.Today, I fitted my new to me interior. Happy is an understatement
View attachment 293618View attachment 293619View attachment 293620View attachment 293621View attachment 293622View attachment 293623
Note, the 326m's in the background of pic #3Looks very nice! The only thing that lets it down now is those wheels. I could solve this for you with a lovely set of 326Ms![]()
