E89 roof won't open
First step almost always on E89s with mysterious electrical problems is get a new appropriate battery ..then see what happens..
My battery has been changed 2 years ago, still under warranty, car starts perfectly, OBD values are "voltage 14,59V" "voltage measured by IBS 14,83V"
Does not seem a battery problem to me...
Could it be because battery is stronger (80Ah) than the 70Ah standard ?
The 80ah battery definitely won't cause a problem..but..your readings from your OBD reader suggest inconsistent battery status ...
So often on E89s a simple A/B swap helps eliminate gross errors
Varta is a very good brand and it seems unlikely..but..it happens all the time..
As Chippie said corrosion on the CTM connector pins or water inside the CTM MAY be issues..again we've seen them here
Can a wrong battery status bring other problems ? Roof opening ? Others... My OBD reader gave me a list of errors and I am checking them all...
Engine electronics
30C6: 0x30C6 engine oil pressure sensor, plausibility
2A19: 0x2A19 Tank venting valve, control
2A94: 0x2A94 crankshaft sensor, signal
2D27: 0x2D27 air mass meter
2AA8: 0x2AA8 variable intake system actuator: control
2AA9: 0x2AA9 Variable intake system positioning motor 2: Control
Soft top module
A690: Hall sensor VSW5.1
A698: Top hatch open
A692: Hall sensor VSW5.3
Dynamic Stability Control DSC8 Plus
5F1C: 5F1C - Info entry: Active brake intervention for overheated brake discs.
Instrument cluster
A559: KL30g_f shutdown
Engine electronics
Soft top module
Instrument cluster
On my 35is when I bought it ..it had 145 errors..most cleared with a new battery and error clear
Clear the errors and see which come back
There's a fucked-up drainage system under the car, at the vertical of the battery. A button/cork, could not see clearly, had to keep my finger pushing it to evacuate the water, just a trickle, took me 10mn, need to have a proper look at it when I can get under the car more easily
Maybe the Kombi is not sending an appropriate speed message to the CTM to allow it to start opening?
there is a drain...
I agree with you that it is important to identify why there is water, but there is a "drain"
Below the battery? That was never intended for water, just for production purposes.
I don't know where it is exactly inside, "below the battery" was to position it approximatively.
You can find it under the car, when I pushed on it, water trickled and I was able to empty the water that was inside the battery compartment.
Ground was soaked, I did not look too much.
Just rained again, but not enough to cause the water damage again.
Here it is, a little bit on the driving wheel's side, 50cm approx from the rear.
News about my problem
Now, the boot does not open anymore and the windows don’t close…
Have to check the forum to see the method to force-close them
