Straight bolt on, and doesn't break the bank. Nice, easy upgrade.Same car as you so potentially an “easy” upgrade. Thanks.
Cleaned beige seats with bleach, always comes up a treat.
Then i used Ford beige spray paint to touch up the worn bits.
Tried in past the leather dye stuff but never much good.
It’s the most effective version of any option you can fit to an E89 bar having the roof up..Bit the bullet and ordered a new wind deflector from BMW. The headrest meshes and brackets are in place, annoyingly the previous owner sold the centre one prior to me purchasing.
EBay searches for a used one, breakers and forum classifieds proved fruitless, so took advantage of a 20% off voucher on eBay to bring the price down.
I’ve read varying accounts on how effective it actually is, but getting it more for completeness rather than anything else!
With some difficulty! Like this the drivers door opens almost to the first notch and the wall has padding so the door doesn't get damaged. It's a little bit of a squeeze and requires some manoeuvring but it's doableLeakyturnip, may I enquire as to how on earth do you extract yourself from your Z4 once in your lovely but quite narrow garage. I need to park mine 6 feet away from anything before falling out with as much style as my old body can muster.![]()
Ooooohhh they look sooo good..!All finished. Just have to cure now. I’ll pop them in the oven on a baking tray with grease proof paper for 30 mins gas 80 degrees once the wife goes out. Works a treat![]()
It would appear BMW had the same thought as me!OK, I thought it was a BMW "W" model I hadn't heard of....
That's simple, just need to do a handstand to check the calipers on one side... twilight zoneIt would appear BMW had the same thought as me!
Take a look at these none refurbished brakes.
BMW 340mm M Performance Brembo Brake Calipers For: 1 2 3 4 Series F20 F22 F30 | eBay UK
We are your premier source for new OEM (genuine) parts for Japanese automakers, specializing in all Mitsubishi Lancer Evolution models, from Evo I to Evo X, encompassing every chassis code including CE9A, CN9A, CP9A, CT9A, and earlier iterations.www.ebay.co.uk
This , I can so relate to thisI need to park mine 6 feet away from anything before falling out with as much style as my old body can muster.![]()
Well, did you
- Replaced both tail lights for shiny new OEM versions - with the car having been garaged most of its life, they were more filled with dirt and dust than water—really simple job (if I hadn't had to fish out one of the push clips from the depths of the boot when it pinged off).
I did, although not using the above, but using some extra strength gorilla grip stormproof duck tape on both sides of the hole. I expect that should do the trick!Well, did you
It is absolutely essential that no water gets into the trunk, as this would damage the hydraulic pump within 9 months!
- seal the 3rd hole that isn't used anymore with newer tail lights? BMW offers a round label for it, a waterproof tape from both sides would be sufficient as well. Partnumbers:
63217216997 Snap-Lock-Coupling
07129904381 nuts
07147162569 "protection foil"- carefully pull the 2x2 gaskets/seals into the trunk and not only pressed the housing onto the body?
So as this has niggled my OCD I checked a colleagues car which is a 2017 1 Series. Both front and rears are as mine are. So if BMW were happy, I can live with it. I was prepared to re-do one of them but I will save my time and money.That's simple, just need to do a handstand to check the calipers on one side... twilight zone
Swapped out the salmon relays for some shiny new ones sourced from BMW dealer. 5 minutes job.
Got me thinking too.... so I checked parts online, Japan auction... f**k me, they've done it globally heheSo as this has niggled my OCD I checked a colleagues car which is a 2017 1 Series. Both front and rears are as mine are. So if BMW were happy, I can live with it. I was prepared to re-do one of them but I will save my time and money.
But I do get your point.![]()
