So have purchased the calipers and the pads. Pads I purchased were these Hey, check out TEXTAR https://m.autodoc.co.uk/textar/8036574
I already have 340mm discs and the correct splash plate. 👍
Prepped etched and base coat on. Waiting for decals to arrive the will 2K lacquer. I’ll let them cure for two weeks then fit them. The colour is Bentley Grey metallic.
All finished. Just have to cure now. I’ll pop them in the oven on a baking tray with grease proof paper for 30 mins gas 80 degrees once the wife goes out. Works a treat👍
Because that’s how they landed. Most people will not flip from side to side so will never know🤪🤣😂
To be fair it’s a valid observation. However I’m not going to die in a ditch over it. They are set in stone now.
Before I trawl this thread, are you telling me I can fit M140i discs and calipers to my Z4? 😛
So I fitted M performance six pots to my 23i. I only needed to change the splash guards. Then add the 340 mm discs and correct pads and calipers.
My current car has 340 mm discs and correct guards so I only need the calipers and pads.
You may need the correct pad wear sensor.
Reactions: CNR
