I see why you have moved theI moved the 10mm spacers to the rear and added 12mm ones to the front. The rear has definitely beefed up well now.
Also changed the calipers from red to black while I was at it.
In an ideal world the front could do with a slight drop, but wouldn’t want to risk having it any lower on the roads round where I live.
Anger spacers to the front… assuming you have the 8” wide rim on the front, the offset is 8mm more than spec for a z4 front rim so your 12mm spacer is the equivalent of stock plus 4mm. Rear offset is only 1mm different from the 9”wide 326m rim so the 10mm spacer complements the front nicely for an OEM+ stance. Nice work sir.
