Data logging the fuel pressure rail with MHD or Protool would have highlighted the problem..FWIWIt would seem someone has been at the High Pressure Fuel Pump before me as the left bolt (nearest the firewall) had been overtightened and the thread stripped. Literally took it out with fingers only. Anyway, new pump installed and slightly longer bolt used as a temporary fix until I change the rocker cover in 2 weeks and the new pump is transformational. The old one must have been failing the whole time I’ve had the car (just a month) until it finally gave in yesterday. The car now feels much more powerful through the rev range especially higher up as it gets up on the cam. Very happy with the fix and it was super easy to do. Key points if you tackle it yourself are
1 Try to have left the car for a good while prior so there is little fuel pressure in the lines. We had a few drips on to a shop towel but nothing much really. Dealing with the high pressure fuel is the only scary bit.
2 Make sure that you fit the new pump carefully tightening both bolts down evenly on to the cam follower below, and importantly ensure that the engine is at bottom dead centre before installing the pump. Use a 22mm socket on the bottom pulley at the front of the engine to find BDC and stick your clean finger on the cam follower and you will feel the bottom of the stroke. If you don’t do this, you will destroy your new fuel pump on first start up. Be careful.
3. Torque spec for the 2 bolts on the pump is 12NM. EXCEED THIS AT YOUR PERIL. The fuel lines torque to 32.5NM. Be certain that these are tight. Fuel spraying on a hot engine is a bad day.
Took 30 mins altogether. I reckon 15 if I did another tomorrow.
