Permission to feel just a tiny bit smug?That's what comes up on EPS
OK, i'll see what I can find regarding the engine speed signal.Can't view them separately just the screenshots I showed
Well that's on the list. Got to be worth a check of that first?On my little code reader it shows camshaft position sensor is faulty
Can't see it mate, sorry?That's the SIM part number can't get to the pillars today as raining will try to remove seats tomorrow and have a look
OK, well that's pretty helpful. Crankshaft sensor first then.Ok another little update I rerun the tests with the black plug from the SIM module unplugged only error that came up was the 2 showing on the gm5
Apart from that when rerunning the test it did show dme error crank shaft sensor maybe this could be the fault that I'm looking to not really too fussed about the airbags at the moment just want the engine running properly and the power steering working
Aye. Now you are still lost, but have company.Ok make sense now will replace the crank sensor tomorrow and report back with the results fingers crossed will get some good results thanks for all your help I would have been lost without you
