Following on from my using some Hyperco 96nm/mm rear springs in lieu of the broken, rusted (maybe coil bound) 70nm/mm orginal Ohlins spring.., I decided to tackle the front end.
As Ohlins only made one kit for all E89s I pondered how they manage with say a 28i Manual with 1480kg weight 705/774 f/r and a 35is at 795 / 815f/r to work out one set of springs would work..given I've got another 30kg at least plus roof down..say 870kg rear..
Sadly Ohlins UK distributor couldn't find any of the 70nm/80nm spare springs..not helped by refusal to disclose the actual part numbers..
Repeated searching for a solution finally resulting on a chap selling a set of Ohlins R+T springs for a Boxster 987.2..and voila..some brand new springs 70nm/80nm for a snip..about 25% of the Ohlins price if available..
So got these brand new babies..
In addition these Hilka spring compressors look like I can compress the springs in situ to reduce their height to aid removal..and then use them rebuild the coil overs with the Ohlins R+T Boxster 80nm rear springs!
