Not at all bud. I wanted to check anyway. Sure enough there was a kink where you said it'd be.Damn. I wasted your time, sorry.
I’ve changed several control modules. Never needed any form of pairing.
Bloody carUnless there is a dodgy connection in the module plug and disturbing it is making it work again for a while?
In car, doors shut. Lower drivers window, when it gets to the bottom press and release the button four times within 10 seconds. Then raise the window and repeat the four clicks up in ten seconds. Do the same with the passenger window.Bloody car
Roof not working again....but i have a red light.
Roof wasn't opening with the key in the door so I tried a window reset but think it needs redoing.
Do you have a method you use.
Tried it but didn't work.In car, doors shut. Lower drivers window, when it gets to the bottom press and release the button four times within 10 seconds. Then raise the window and repeat the four clicks up in ten seconds. Do the same with the passenger window.
See if the roof works with the windows lowered first.
Thanks bud.Well sounds like you’re slowly winning at least
That could just be someone disconnected it.Thanks bud.
Once I get this one properly ticked off, it'll be the turn of the flashing lights but no sound from the siren conundrum when alarm triggered![]()
So close to putting a sledge hammer to this car.That could just be someone disconnected it.
Though I seem to remember there is a coding option to have no sound too?
It MUST be a bad connection somewhere. It's finding where that is the difficult bit, as you well know.So close to putting a sledge hammer to this car.
Roof working fine last night. Hasn't moved from it's spot in the garage.
Didn't work at first this morning...then did....and now doesn't again.
Always the same symptoms....no lights on the roof switches when pressing.
So frustrating![]()
So apart from wiring, the only thing you haven't changed are the two relays, is that right?So close to putting a sledge hammer to this car.
So frustrating![]()
I've just taken the 3rd roof module out, put the original one back in and disconnected the battery for a couple of minutes.So apart from wiring, the only thing you haven't changed are the two relays, is that right?
Where are you?
I have spares.
If you haven't already looked at them, drop the passenger side footwell trim under the glovebox and check those two relays. If the scuttle panel fills up with leaves you can get water leaking past the pollen filter intake and the relays are right under that. I've just dug out two spares (they are both the same), so let me know if you need them.I've just taken the 3rd roof module out, put the original one back in and disconnected the battery for a couple of minutes.
Reconnected the battery and the roof is working again....for now
You know when you get the the stage that you just dont trust the car and nothing that you've done actually pinpoints the issue.
Feel like screaming![]()
No codes at all.....apart from a historic boot latching that I can't seem to shift.If you haven't already looked at them, drop the passenger side footwell trim under the glovebox and check those two relays. If the scuttle panel fills up with leaves you can get water leaking past the pollen filter intake and the relays are right under that. I've just dug out two spares (they are both the same), so let me know if you need them.
The fact that every time you disturb the system it starts working again would definitely suggest an electrical connection issue somewhere. Definitely no codes showing? Sounds daft, but no random codes for speed sensors? Just on the off-chance the car thinks it's moving too fast to operate the roof.
That's them.Looks pretty clean under there. Assume it's the 2 purple ones
You're right. It's only worth £3.50. But I'll nip down now with a fiver.Instead of crawling around the footwell of the shitbox (e85) I could be out roof off in one of my other toys![]()
Is it worth disconnecting the battery 1st or OK to do live. Maybe disturbing them may helpThat's them.
