All... I have a fully functional convertible top (for now?). The last of the materials I needed finally made it late Monday and I put everything back together last night. I ran new, more flexible, wires from just above the trunk lid up to around where the microswitch connector is, on both sides, replacing all six wires.
Materials:
- New roof bolts (Factory bolts have a thread locker on them. It looks blue but holds like red! Manual says you can re-Loctite and reuse but I'd already purchased the package of bolts and shims. Cost was about $45)
- Zip ties (lots of zip ties)
- 22-24 ga control wire in various colors (I ordered the package of 28 qty 10' 22 ga wires from Amazon)
- Cloth harness tape
- Self sealing tape (All I could find in the states was silicone tape... It worked fine)
- Solder and shrink wrap or solder-seal butt connectors and shrink wrap. ( I had 24-26 ga solder-seal connectors. When heated, they heat shrink onto the wire and there is a bit of solder that melts and joins the wires. I shrink wrapped the connectors to protect them. If your soldering skills are better than mine, solder would be just fine... use what you got.)
- Blankets or towels to protect the roof section
- Silicone spray to lubricate the defroster connectors prior to removing, (I also sprayed the inside of the heat shrink to help get the wire through)
- Heat shrink tubing (I used 1/8" and some misc 5/32") I heat shrink wrapped the new wires vice using cloth tape for additional protection and just ease of installation. I had to do this in two pieces for each wire pair because the wire was so flexible... it was like pushing a noodle through a hose. If you use tubing that is a bit larger, you can probably do it in a single section but make sure you choose a size that will shrink up enough.
The lessons learned in my post above still apply. Some additional items...
- The manual says to remove the center bracket off the roof prior to re-installing. Your mileage may vary but I found this to be unnecessary after doing it. There is way more play in that slot than there is in the roof brackets.
- I used 3.85 mm 3d printed gauges to properly space the roof along the seam with the front roof. Also probably unnecessary. I'll caliper the opening later but it seems pretty tight. Spec is 4mm +0.8/-1.
- When I re-attached the roof and tightened everything down, with the same number of shims as were in before, the driver's side of the rear roof section was a bit low. I put in a second shim and that fixed it. The bolt kit comes with more shims than you will ever need!
- I probably left too much spare wire at the splices. There is not a lot of room between the shell and hydraulic arms. If you leave extra wire, it will be a tight fit. I made it work but if I ever have to do this again, I'll try to minimize excess wire.
- Following RobbiZ4's recommendation, I wrapped the hydraulic lines in the middle bow (where most of the work stress occurs due to bending around the back of the hydraulic arm). Before wrapping, I snipped the sharp edges of the hose insulation and then wrapped from both ends of the bow with silicone tape, meeting in the middle. Once wrapped in self-sealing silicone tape, I put a layer of cloth harness tape on the lines to prevent the lines from sticking to each other.
- You will probably need help to re-install the roof. It's not especially heavy but, without the shell on, there are just too many degrees of freedom between the roof and arms. Extra hands are priceless. My neighbor came over and it took us about 30 mins or so.
- All said and done, its probably 1-2 solid days of work if you take your time. I started Friday night and finished the following Tuesday but I also waited a few days for the side cutting pliers to snip the sharp edges of the hoses and for the heat shrink and silicone tape. If yo plan better than me, you can finish in a day or day and a half easily.
I tested opening and closing before installing the roof to ensure the fault did not return and everything worked great. Tested again with the roof installed and ran it a few times from open to close. So far so good. I'll update if any faults return or if I have other issues but I'm going to mark this as done.
Special "Thank You" to RobbiZ4. His advice and expertise were priceless. He was also amazingly responsive to my questions and very encouraging. His help definitely made the job easier. Robbi... next time we're across the pond (or if you make it to Nebraska) I owe you a beer!
