To clarify, you think the bit stuck in the base on the car, in my picture, is the one I should try removing?Replacement aerials come with a few different threaded adaptors to fit different cars. I suspect that it may just be the adaptor stuck in the base. Try turning it with pliers, or two nuts put on and locked together, then turn the lower one.
I think so yes. though my knowledge is based primarily on E85To clarify, you think the bit stuck in the base on the car, in my picture, is the one I should try removing?
This is what I was planning, just needed to check.
For reference, here's my e89 with the aerial removed.
So that's the end of this thread then.So the thread that was sticking out of the car came out really easily with pliers turning it.
Thanks for the help everyone.
Hurrah..whippy for ever !🏎Not quite - I did this too, this afternoon. Finally got a whippy back on!
