Hello All... I solved my SOS Failue problem and now have a roof problem. The roof opens fine but, while closing, I get the A68D fault and the roof travel stops. Description is "Micorswitch, roof shell 2 closed, right." With the car connected to Protool and watching life data from the microswitches on the rear roof shell, both switches change state when manually cycled. While closing, the roof stops about 2 inches above the rear deck and gives the warning. Neither the right or left switches indicate that they are closed when the error comes in but the only code it throws is the A68D. I've done a visual inspection on the wire loom and everything appears to be in good condition with no chafing. Manipulating the wires with the switch depressed does not cause it to change state so I don't think it is a broken wire. It almost seems like the logic is looking for the switch too soon. This just started happening. I have not done any coding on the convertible top or anything else that would affect that. I recorded a video here:
In order to latch the roof, I have to turn off the car and wait for hydraulic pressure bleed off and for the roof to drop to the deck. Once it is past whatever point is throwing the code, I can clear the code and latch the roof. This means that I'd have to keep a tablet and Protool handy in order to reliably be able to close the roof. Not ideal.
All of the coding options for the roof are in German. I wouldn't have any idea where to start adjusting sensitivity to see if I can get it working reliably again. Any help would be greatly appreciated.
