derin100
Active member
Ah! An interesting thought!I wonder if they forgot to do the ABS/DSC unit bleed procedure?
Because, when I drove it and braked hard, I don't recall feeling the ABS coming in....
I am basing this thought on my E85 knowledge, but would assume the E89 is very much the same?Ah! An interesting thought!
Because, when I drove it and braked hard, I don't recall feeling the ABS coming in....![]()
You could well be right!I am basing this thought on my E85 knowledge, but would assume the E89 is very much the same?
It also mentions in NewTIS that sometimes the rear brakes, with the electronic parking brake, cannot be bleed completely using the normal method. It then goes on about having to remove the calliper and turn it upside down to get the rest of the air out?You could well be right!
I think this is all a task for my Indy to sort out….It also mentions in NewTIS that sometimes the rear brakes, with the electronic parking brake, cannot be bleed completely using the normal method. It then goes on about having to remove the calliper and turn it upside down to get the rest of the air out?
